04-02-2008
Clean the sail track before lubricating it.  Use McLube Sailcote to lube the sailtrack.
Check VHF antenna, and replace it and the wiring if it is questionable.
Inspect the spreaders, spreader bases and spreader tips.
Check the masttop exit slots for burrs or damaged areas that may fray or chafe the halyards.
Replace spreader boots with ones that don't trap moisture against the rigging. Prefer the woven synthetic ones over the leather or plastic kind.
