04-04-2008
Chevron-
Putting a trap in the deck pumpout fitting line is a really, really, bad idea. If you're sailing with the tank that full on a regular basis, you either need to have some way to pump it out yourself, or get a bigger holding tank.... The deck fitting should be pretty well sealed when it is screwed shut, so you shouldn't have much in the way of discharge through it, even when heeled way over.
