04-04-2008
H216Sailor,......
I am not real familiar with the 10GM model, but my 30GM uses the same oil (weight and type) in my tranny and the motor crank case.
I am not sure I agree with you that the tranny is fairly constant in temp. when operating. As you put more load on the engine, I would think the tranny would heat up unless it is actively cooled. Mulitweight oil allows the oil to "flow" in a varity of temperatures, whereas a single weight, works well in a more narrow temperature range. So again, I would check the manual or with a Yanmar dealer before you substitue a single weight oil for a mulitiweight. They may say it is fine, or they may say that the recommend the multiweight. Also, as rperret states, the tranny oil and the engine oil could be different depending on the tranny. Best to check for your specifc tranny.
I don't know who makes the Yanmar Oil, could be anyone. It's good to know that the Rofella is recommended in your motor. If that is easier for you to get, using it shouldn't be an issue. I can easily get the Yanmar stuff, so I do.
Good Luck with it.
DrB
