-   -   bow rollers (http://www.sailnet.com/forums/gear-maintenance/41980-bow-rollers.html)
NALANI13 04-05-2008 02:44 PM
bow rollers
we do not have an techinical information for the bow roller that was installed on the boat by the previous owner. the support plate is recessed into the bow. it is a dual anchor bow roller. we are interested in getting a second heavier anchor and are trying to figure out if the existing roller will support the load. Any ideas?
Freesail99 04-05-2008 03:40 PM
Try and post a picture after you have 10 post. It would really hep us see what your talking about.
sailingdog 04-06-2008 07:45 AM
It would also help if you said what kind of boat you had. Chances are more than likely, if the bow chainplate is part of the bow roller you're looking at, that the work was custom for the previous owner, rather than a mass produced piece.
NALANI13 04-06-2008 12:37 PM
bow rollers
it is a 2000 moody 46'. unfortunately when premier marinas purchased moody it is impossible to get any documentation from them. apparently they are still in transition mode. i will post the picture as soon as i can and thanks for your responses!
camaraderie 04-06-2008 01:03 PM
Nalani...There will be NO issue with the roller supporting a heavier anchor provided the roller was installed with decent backing plates rather than just bolts and washers. The Moody 46 is a robust boat and should have be designed far in excess of any anchoring loads which may be imposed by a heavier anchor.
sailingdog 04-06-2008 01:07 PM
Cam-
The only issue is that the bow roller was installed by a previous owner, not Moody....so the installation methods and quality of materials is in question. However, if the roller was designed as a custom part and includes the bow chainplate in the design, it is very likely to be more than sufficient for any reasonably sized anchor for that boat.
NALANI13 04-09-2008 05:36 PM
I think i confused the issue - since i don't have any tech spec's i am not sure whether it was indeed custom or standard installation. The owner customized a number of things.
camaraderie 04-09-2008 05:58 PM
Nalani...it doesn't matter. What matters is if it is installed CORRECTLY. Check the backing plates and take some pix when you can.
jimmalkin 04-09-2008 06:00 PM
Ah ha - the famous prior owner "customized a number of things." Be patient and examine carefully - after 5 years, I am still removing "customizations."
