bilge pump DQ - SailNet Community
Blogs
Old 05-28-2002
halyardz is on a distinguished road
bilge pump DQ
I just wired a new RuleMate auto and it doesn''t really pump the bilge entirely dry. It leaves about 1/2-3/4" of water there. It did pump the main portion out. Its that float switch on the autos set to leave some water there? It is mounted on the bottom of the bilge in the middle. The Rule website is fairly useless.
Old 05-28-2002
lgsailor52 is on a distinguished road
bilge pump DQ
You pump and float switch are OK. Some water is normal.
Old 05-28-2002
VIEXILE is on a distinguished road
bilge pump DQ
The depth to the pump impeller from the bottom of the bilge is at least 1/2". Beyond that, a pump will put water into a hose, but when the switch stops floating, it''ll shut off. Any water in the hose will drain back into the bilge. An antibackflow valve in the line would prevent this. Besides, separate float switches suck. Get a low amperage draw(500 gph or less) rule pump with internal switch for the bottom oof the bilge. That way bilge flotsam, hoses, etc., can''t lay across the switch. Throw away the float switch and mount your (probably) Rule 1500 8" to 10" above, with it wired to a manual switch. Anything happens, you''ve given it your best effort.
Old 06-04-2002
scottcallahan is on a distinguished road
bilge pump DQ
i''ve never seen a rule product that doesn''t leave 1/2 inch of water. the best you can get is 1/4 inch with a different setup. the setup goes as sutch you get a diaphram pump and mount it close to the bilge but not in it. run a hose to a strum box otherwise known as a bilge strainer.
the diaphram is designed to let the water only go one way. and stops water from flowing back. and the strainer allow''s you to drain to a lower level.
but all of this is not worth doing. the thing
i would do, is sponge out the bilge and get it dry so you can look for leaks and fix them . and if you fix them you wont have a wet bilge.
hi VIEXILE i''ve seen you on alot of these, are you a marine technitian or do you just have alot of time around boats?
-scott-
Bilge pumps oz_hole Gear & Maintenance 1 06-06-2003 02:36 AM
Bilge pump GeorgeTay Gear & Maintenance 4 04-03-2003 04:03 PM
Oily Bilge dscottl Gear & Maintenance 3 06-12-2002 12:29 AM
Bilge pump dilemma zeilfanaat Gear & Maintenance 3 04-19-2002 06:22 AM
Bilge Question r3333 Gear & Maintenance 0 11-08-2001 09:11 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
