04-07-2008
No reason you couldn't do that. It would certainly make getting the sails up a lot simpler.  My recommendation would be to mount the clutches on a base, and have the bases pop riveted to the mast, using stainless steel or monel pop rivets. The simplest base could be a piece of bent aluminum.
