04-08-2008
purveyor of mischief
i may actually know this
i recently recommissioned my boat and got a lesson in water heater, engine coolant mgmt.
do you have a coolant overflow reservoir? if not, create one.
fill the reservoir with antifreeze, (matching the color you already are using in the engine), and take the radiator cap off and start your engine. after the thermostat opens, the reservoir antifreeze will fill the radiator. when the level reaches the very top, (read no air space), replace the cap and tighten properly. then refill the coolant in the reservoir, and voila, you are done. (granted it will take longer than it took me to type this, and i'm a slow typery person).
oh, do this while everything is still cold..(all you saying "duh"..shaddup  )
happy 8th of april to all.
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
