04-09-2008
Sander-
If the chainplate is clean and the sealant actually seals to it, the corrosion problem is minimal. IIRC, the oxygen deprivation corrosion problems require moisture to be present, particularly a problem when saltwater is trapped against the surface. That wouldn't be the case with the chainplates, and IMHO they're going to suffer less corrosion if fully sealed off using sealant.
Sailboy-
Don't forget to run a countersink bit over the bolt holes in the hull. This will give the sealant a place to form a natural o-ring type seal and will help keep them from leaking for a long, long time. Faster's advice on masking off the area is excellent and the way to go.
