Old 04-08-2008
NauticalFishwife is on a distinguished road
Send a message via AIM to NauticalFishwife
Caution using wire reinforced water hose
This has happened to us twice now! We had some work done by a great company and they replaced the head intake hose from thru hull to a t valve and then hose from water pump to facet. BOTH of these failed. They had used the wire reinforced, clear water hose. I heard that sick high pitched sound under the sink and found the leak there. Fixed that. Then when opening the thru hull noticed a small pool of water...hmmmm. The wire worked it's way right through the hose and created a leak. The company has stopped using that hose. If you have it on your boat, check it. This is NOT the black wire reinforced hose, but the clear water hose reinforced with wire.
Old 04-08-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Thanks for posting that - is this a documented manufacturer defect as well? It would be great if you could post any pictures of the busted hose - as some would not know if they have it or not but visually...
Thanks again!
-- Jody
S/V "
1983, Barberis Show 38! or
Old 04-09-2008
Don't confuse the polyester fiber-reinforced clear hose with the wire reinforced clear hose. They look a lot alike.
Old 04-09-2008
Good point Sailingdog...and I tried to stress that it is the wire reinforced clear water hose...it is NOT the polyester fiber reinforced clear hose. The manufacturer says it is not a problem, however, the company who did the work has stopped using it and made one of the repairs on our boat and did not charge. The one leak at the thru hull could have been a real mess. Thank GOODNESS I CLOSE my thru hulls when I'm away for any length of time Oh but that's a discussion on another thread! Jody, I'll try and post a picture too.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
