A/C freezing up - Page 2 - SailNet Community
post #11 of 11 Old 04-14-2008 Thread Starter
wfahey's Avatar
Once again I would be remiss if I didn't thank everyone that responded. I went out to the lake on Friday and looked over the unit. The fins were clean but I noticed there were 2 filters being used at the same time. One looked like an ordinary A/C filter, the other was a much finer piece of material that looks a lot like a large scrubber used to clean pots and pans. I removed this one and just used the other filter.
I checked the sight glass in the raw water strainer that feeds water to the A/C unit. It looked clean and water appeared to be flowing. Just to be sure, I shut everything down and opened up the strainer. It did have some debris in there so I cleaned it out and put it all together and fired up the A/C.
It worked like a champ! I am thinking reduced airflow caused by the extra filter and reduced water flow caused by the debris contributed to the freezing of the unit.
Thanks everyone for your input.
Bill
s/v Lucky
Catalina 36
Texas
wfahey is offline
Lost my A/C Power mathislaw1 Gear & Maintenance 12 07-17-2007 12:28 PM
Need to run a/c mooring, no gen? acmecoyote Gear & Maintenance 4 11-19-2002 04:21 PM
A/C on the high seas acmecoyote General Discussion (sailing related) 4 10-26-2002 04:28 PM
Inboard motors in Freezing Weather hunter87 Gear & Maintenance 0 12-31-2000 05:37 PM
