Stainless Steel... - Page 2 - SailNet Community
post #11 of 15 Old 04-09-2008
Swansea, MA
pfatyol's Avatar
If you have some loose fastners, mix up some salt water ~ 1%, and let the fastner(s) soak in it for at least 24 hours, pull out and let air dry. If you see signs of rust. Then most likely 304 or the passive layer has been removed. Salt bath soak is routinely done on surgical instruments to find problem areas in the processing. i.e. laser marking too much power, poor quality forgings. . .
Citric acid based cleaners on SS are a good thing, Citric acid at 20% is one form of passivation solution. The cleaners have no where near the acid concentration to passivate at room temperature.
feel free to email me,
Patrick
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
pfatyol is offline
post #12 of 15 Old 04-10-2008
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by RAGTIMEDON View Post
For marine use, it is not the strength that matters as much as rust resistance. Plain carbon steel, even "soft" free machining steel, will make a screw that will hold parts together. But unless they are immersed in oil, rust will destroy 304 stainless in salt air. They call it stainless, but check it with a strong magnet before you buy! If a magnet has no attraction to it, it will probably last; if the magnet will pick up a screw, it probably will rust. That's a heck of a lot cheaper and more convenient than spectrographic analysis!
After reading this thread, I tried the magnet trick last night on my pile of spares and was rather horrified by the results - more than half of my fasteners were picked up, including:
- A Ronstan swivel fitting!
- Boat nails!!
- All my "stainless" spring clips, sister clips and split pins!
- A large variety of screws, nuts, bolts and washers - some bought from the local hardware store, some from who-knows-where.
Without the magnet, it didn't seem possible to tell to them apart - so I know the test was working. Some of the larger stainless bolts seemed to be weakly attracted, hanging on by the head but falling off without much force (are these an issue? don't know..) and some larger pulleys and hooks were not attracted at all.
I didn't try my stainless rivets, but by my reckoning nearly 2/3rds of the "stainless" fittings on my boat are magnetic.. but have yet to show signs of rust. A bit of a worry!!
Classic30 is offline
post #13 of 15 Old 04-11-2008
beej67's Avatar
Originally Posted by merttan View Post
Will it be company privilege abuse if I get the metal things casted and cut in our titanium medical factory in Turkey?
Not if you cut us in on the action.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #14 of 15 Old 04-11-2008
Will it be company privilege abuse if I get the metal things casted and cut in our titanium medical factory in Turkey? Nevermind for this boat, for the next one maybe
I'll see if I can get some manufacturers' production method
OR get us some gear made out of titanium too.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #15 of 15 Old 04-12-2008
Freesail99's Avatar
I use to be an owner in one of the larger Metal Polishing Companies in America. Whenever we were mirror finish stainless to be used near salt water we always used either 304L or 316L. We had better luck with those alloys.
S/V Scheherazade
Freesail99 is offline
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 04:46 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 06:02 AM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 08:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 08:00 PM
