04-11-2008
You really need to crimp the connections using a proper crimper and adhesive-lined heat shrink tubing.
This is a proper crimper for insulated connectors:
This is a proper crimper for heat-shrink connectors:
Either use double crimp connectors and put adhesive-lined heatshrink over them, or use the single crimp heatshrink connectors instead.
