04-14-2008
I've barrier coated 2 boats and have never needed to re-do the barrier coat. I don't think that, as a practical matter, you ever need to re-do it again, unless it is damaged. In that case, I'd just sand it smooth where it's damaged and re-coat that area. It's possible that it breaks down over a very long period of time, but I have no idea how long that might be. I believe barrier paints came into widespread use in the late 1980s, and there might not be a good record yet of exactly how long they last. If you want to do a bottom job on your boat, stop sanding when you get through the antifouling, so that you don't remove any of the barrier coat.
