Why put a Cunningham on a Genoa? - SailNet Community
post #1 of 8 Old 04-14-2008 Thread Starter
I'm the FNG still...
Lancer28's Avatar
Hi guys -
I just got my new 170% Genoa from the sail loft, and it has a cunningham eyelet (or what I presume is a cunningham) just above the tack.
Maybe I'm being retarded, but why put a cunningham on a Genoa? Should I consider rigging to use it this year? Is it a cunningham in the first place?
Thanks for any ideas!
Robert
I reject your reality and substitute my own.
Lancer28 is offline
post #2 of 8 Old 04-14-2008
ASA and PSIA Instructor
I've seen a cunningham on some one designs where the jib halyard hoist is fixed - the cunnigham is used to tension the luff as the halyard cannot do so. A 170% genoa is pretty unusual, nowadays even serious racers don't seem to go over 153%...was the sail custom designed for light air, where the luff length may be max? If so, the cunningham would be used to adjust luff tension. If your halyard can tension the luff there is no need for a cunnigham. Sounds like a pretty unusual sail.
sailingfool is offline
post #3 of 8 Old 04-14-2008
Sailor
Plumper's Avatar
We have the same setup on the shark. A 180 frac rig genoa with a cunningham cringle above the tack. We never use it but other sharks do.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #4 of 8 Old 04-14-2008
jimmyb116's Avatar
It is a reef eye ? some large genoas have them
Sailing one day at a time
jimmyb116 is offline
post #5 of 8 Old 04-14-2008 Thread Starter
Lancer28's Avatar
No, not a reef eye. It is a light air sail, and custom made. Last year, we used a heavier 170 which kicked butt (4.2 kts on the gauge in LIGHT breezes where everyone else was hardly making way).
SF, that sounds plausible - I'm using halyards, so I won't need it.
Thanks for the help, it was such an unusual thing to find!
Robert
Lancer28 is offline
post #6 of 8 Old 04-15-2008
kiprichard's Avatar
I was in Puerto Vallarta last year when the J Boat worlds were being held. Went down to the docks to look at the boats and every boat had a genoa cunningham. I've never seen one anywhere else so I guess you have to be a pretty serious racer to use it.
Bambino
kiprichard is offline
post #7 of 8 Old 04-15-2008
Ask your sailmaker. Likely they installed the cunnigham to allow you to move the draft forward by further tensioning the luff after you have achieved maximum hoist on the halyard.
The sailmaker should also be able to advise you of the amount of mechanical purchase required.
Hudsonian is offline
post #8 of 8 Old 04-15-2008
Once known as Hartley18
Classic30's Avatar
Dock
It is becoming a trend in the small/medium racing classes to use a cunningham ('downhaul', really) on the headsail. The Hartley 16's have been using downhauls for many years. Two reasons:
1. It's easier (and safer on a small boat!) to adjust a downhaul for headsail draft control than to retension the halyard - particularly if you don't have a halyard winch - and
2. Using a downhaul, you can alter the draft without changing the rig tension at the same time
...but, yes, you've got to be a pretty serious racer to make it worthwhile.
Classic30 is offline
Cutting down a new genoa ian555 Gear & Maintenance 2 01-06-2008 03:22 AM
cunningham ? Mike244 General Discussion (sailing related) 19 12-01-2007 11:58 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 03:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 08:00 AM
New and Improved Laser Controls Dan Neri Racing Articles 0 11-28-2001 07:00 PM
