Old 04-15-2008
NALANI13 is on a distinguished road
blistering
we just removed the cushions in our cockpit and discovered that the fiberglass was blistering behind them. it isn't anywhere else, just there. What is the best way to deal with it?
Old 04-15-2008
EO32's Avatar
EO32 is on a distinguished road
Don Casey's Hull and Deck repair book shows how to fix blisters. It looks pretty easy if you're handy with tools.
He cautions that the blisters are under pressure and the water has turned to acid, so be careful when you pop them. Wear safety glasses.
Basically you grind them down and gelcoat over them.
Old 04-15-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
I would first check to determine if the blisters are osmotic. One way to do this is if when pierced with a sharp knife, a darkish, noxious smelling fluid oozes out from beneath the bubble. Otherwise, moisture may have gotten behind the gelcoat, creating delamination from the fiberglass layer.
Either way, the affected gelcoat needs to be ground down to bare fiberglass, or deeper if delaminated. Then repair the area by filling/fairing with the appropriate compound(s).
True Blue . . .
sold the Nauticat
Old 04-15-2008
there are a lot of areas where the bubbles have opened on an edge so hopefully they aren't osmotic. But there are larger bubbles that may be. I will have to get his book. I am really worried about leaking. thanks for your help
Old 04-15-2008
Wear goggles or other eye protection, since the fluid in osmotic blisters is generally under pressure and can spray...and is rather caustic.
Are you sure they are gelcoat blisters? Paint will also blister in a similar manner.... and if the deck was Awlgripped, it might be paint blistering.
Osmosis in integral FG water tanks sailawaysteve Gear & Maintenance 4 11-28-2007 10:10 PM
Questions about hull blistering marlinspike6 Boat Review and Purchase Forum 11 03-03-2007 12:38 AM
Blistering SunnySideUp General Discussion (sailing related) 83 11-08-2006 10:35 PM
Hull Blistering Sue & Larry Buying a Boat Articles 0 09-01-2002 08:00 PM
mid 80'' french boats blistering rikulle Boat Review and Purchase Forum 1 12-09-2001 05:24 AM
