Paint Build-up or Barrier Coat? - Page 3 - SailNet Community
post #21 of 30 Old 05-08-2008
What tool/method did you use to sand off the paint? I have an 83 Catalina 22 with years of bottom paint build up that I'd like to remove. Thanks,
Mark
mdistel is offline
post #22 of 30 Old 05-08-2008
Mdistel-
If you have a local vendor that does sodablasting, that's what I'd recommend you do. It is far easier than trying to sand years of bottom paint off the boat, and far faster.
sailingdog is offline
post #23 of 30 Old 05-08-2008 Thread Starter
Mdistel,
I used a 5" random orbital electric sander and tons of 100-150 grit sandpaper. It's a lot of work... but it turned out very nicely. So far I've sanded the entire hull with the exception of the wing keel. My wing keel has deep cracks on the side and is pretty difficult to sand because of the unevenness.
I contemplated soda-blasting the keel, but my pressure washer seemed to remove a good bit and I may hit it again with the random orbital to see how it does. Either way, I will have a good bit of filling to do on the keel.
Good luck-
cas8100 is offline
post #24 of 30 Old 05-08-2008
beej67's Avatar
Mark
I used one of these:
Makita Axial Sanders and Polishers
...with a rubber backup pad to it, and a whole box of adhesive backed sanding disks .. I think I used 50 grit. Took me about 2 days to do the bottom of my boat, including the keel.
That's a DIY project that I'm glad I did, but will never do again. I think I sneezed gelcoat for a month.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #25 of 30 Old 05-08-2008
Thanks guys.
I need to determine how far I want go considering the value of the boat (we paid $3000 last year, included dockage ~800) and the likeliness that we will upgrade to a larger boat.
At the minimum I will rough up the bottom, clean with thinner and apply another coat of copper bottom paint. I will also clean up the keel and fill any voids.
Mark
mdistel is offline
post #26 of 30 Old 05-08-2008
SailKing1's Avatar
I would suggest that you sand to gel coat for a couple of reasons.
1. Its a new to you boat, see whats underneath.
2. Some bottom paints especially micron do not adhere well to others. (that appears like the cracks and chipping in your pics.
3. Fresh barrier coat, better protection.
4. Peace of mind.
In the long run the expense and time will be less doing it right the firat time. Trust me from experiance.
SailKing1 is offline
post #27 of 30 Old 05-09-2008 Thread Starter
I did the same the first time I sanded my bottom paint and this time around I bought a 3M 6800 full face respirator. Best purchase I've made in a long time. You can put the general particulate filter onto it and the respirator acts as eye and respiratory protection in one. I've used it on several non-boat projects as well.
cas8100 is offline
post #28 of 30 Old 05-09-2008
beej67's Avatar
Yup, that'da been nice. I went with the Saftey Goggles and Dust Mask approach.
Even so, it took us about a week start-to-finish to do our P323, and between the time spent by me and my wife, and the yard fees, and the materials, and each of us burning a week vacation from work, it's totally worth it to pay someone else.
beej67 is offline
post #29 of 30 Old 05-09-2008
A little less cheek
ianhlnd's Avatar
That looks like the exact same problem I had on my Catalina 30 many years ago. Following a paint job done by the local yard, chunks of paint were falling off. The yard rehauled the boat, and had several inspections done and factory tech reps consulted with the conclusion that different paints were used over the top of the other and the earliest applied paint was rejecting the latter. In other words, some bottom paints aren't compatible with others.
Their solution, sand blast the hull to gelcoat, then repaint. At their expense of course as they had done the painting.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
ianhlnd is offline
post #30 of 30 Old 05-09-2008
I'd definitely recommend the full face respirators over the googles and half-masks... they're a lot more comfortable, and no dust gets into your eyes.
DO NOT SAND BLAST FIBERGLASS... Sodablasting is much safer and won't damage the laminate as easily. Sandblasting can eat away the paint, the gelcoat and layers of laminate if the operator isn't careful.
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 10:18 AM
barrier coat BarryL Gear & Maintenance 104 05-20-2009 02:18 AM
Best way to remove bottom paint and barrier coat from rudder saurav16 Gear & Maintenance 9 04-11-2008 03:46 AM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
bottom paint barrier coat rbh1515 Gear & Maintenance 2 02-25-2001 04:52 PM
