04-17-2008
CAL 27 Sound deadening/insulating ? material lining sides of Engine Compartment
The sides of the Yanmar 1GM engine compartment in our CAL 27 is covered with some type of soft foam type lining material that is unfortnately coming off the walls. Unfortunately, I don't know the proper name of the material but since it is falling off the walls I would like to remove what is left of it and replace it with an appropriate material that would perhaps function well as a sound deadening material and insulation from the heat of the engine compartment.
Any advice on what material to select and where one might get it would be appreciated.
Thanks,
H216Sailor
