Old 04-18-2008
Irrationally Exuberant
arf145 is on a distinguished road
Propeller Nut Torque
I had the yard pull the propeller on our Pearson 28 (1" shaft) so I could have it rebalanced. Great--I've got this shiny, balanced propeller and a new cotter pin, slid on the propeller followed by the two nuts. But how much torque on the nuts? With very little effort on a wrench, they've cleared the hole for the pin. The prop shop guy said to use the outer nut to tighten up the inner.
What's my move here?
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 04-18-2008
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
Tighten up the inner nut with a wrench, you can get maybe 40 or 50 lbs. Then the outer nut to about the same. The outer nut will lock the inner nut in place. Don't forget the cotter pin.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Old 04-19-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
No big deal, just crank both nuts down as tight as you can without breaking anything. BTW, contrary to popular belief, the thin nut goes on first with the thick one going on after it.
"Clean bottoms are FastBottoms"
Old 04-19-2008
Rockter will become famous soon enough
Don't grease it either. It helps it go on, and come off.
Old 04-19-2008
Thanks guys. No grease (got that from the propeller guy too), inner small, then outer large. Pretty darn tight. Cotter pin.
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Keel Bolt Torque GordMay Gear & Maintenance 2 05-07-2003 09:34 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Propeller Mark Matthews Gear and Maintenance Articles 0 07-24-2002 08:00 PM
Propeller Problems Mark Matthews Gear and Maintenance Articles 0 05-27-2002 08:00 PM
Check the Propeller Tom Wood Gear and Maintenance Articles 0 02-25-1999 07:00 PM
