Old 04-19-2008
Ariel1989 is on a distinguished road
water pump
Hi everyone, I purchased a catalina 27. My water pump won't turn on. I checked voltage at the panel. voltage at the pump, turned the switch on at the panel. Nothing happens. Can anyone help me with this problem. I am new to sailing...HELP
Old 04-19-2008
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
Welcome aboard Ariel,
With the switch on is there volts at the pump or load side of switch? If not there may be an inline fuse, look at the wires.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Old 04-19-2008
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
With the switch on, test for power and ground at the pump. The easiest way is to put a meter on the power and ground wires at the pump. You should have battery voltage with the switch on. It's important to have the pump still plugged in when you test this. A corroded wire may be able to pass the voltage but not the current. With the pump still plugged in, it will pull enough current to knock the voltage down if it's a corrosion problem. I use pins to probe into splices if something is hard wired.
If you have battery voltage, then replace the pump. If not, you'll need to find out if the problem is power or ground. Don't just assume the problem is on the power side.
I've got to get on the road to the lake, someone help him out with voltage drops if he needs it.
John USYacht 27 "Cora Lee"
Old 04-19-2008
You say you have voltage at the pump... Give the pump and sharp rap and see if it comes on... If it does then the pressure switch is sticking. It's a simple matter to pull the switch apart, clean up the diaphragms, ports and spring and reassemble it. If you tap the pump and it doesn't come on I'd still pull the switch apart and look into that.
1984 Fast/Nicholson 345
Old 04-19-2008
BarryL's Avatar
BarryL is on a distinguished road
Hello,
For some reason, it seems common for the on demand fresh water pumps to fail. I have replaced two of the PAR / Jabsco pumps. Fortunately, they are cheap and easy to replace.
The second time it occurred to me to install a higher quality pump. Unfortunately (or is it fortunately?), if I install the same pump the wiring and mounting lines up, so I just stick with it.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 05-26-2008
FairfieldSupply's Avatar
Pump Builder
FairfieldSupply is on a distinguished road
Just food for thought. On some Jabsco pumps if the pump sits in a very humid condition for a long period of time a film builds on the commutator and depending on the pump, try to spin the motor by hand a few times to reestablish contact between the brushes and the armature. Don't rush to condemn the pump when it can be repaired. Even though the Jabsco pumps say they have sealed motors condensation can still build in the motor under the right conditions.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
