Old 04-19-2008
sailingcal21's Avatar
sailingcal21 is on a distinguished road
Leaking Rudder
I've had Karma out all winter to have the bottom paint removed. Now that the rudder is cleaned of paint, I've noticed that there was some swelling and cracking at several points about 6" from the trailing edge of the rudder. No doubt there is some tabbing material there.
I drilled some pilot holes around the swelling and water started seeping out, Then I drilled some pilot holes around another swollen area about 4" from the leading edge and 4" from the bottom. I was rewarded with a steady stream of clear water for several minutes.
To repair, I'm gonna gouge out the areas for further inspection, fill and patch with fiberglass.
I'm presuming that I have a leak at the rudder post.
Does anyone have an idea about the effort required to drop the rudder on a 1981 O'Day 34?
Scott
s/v Karma
Short Pump, VA
1981 O'Day 34
"No matter where you go, there you are."
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
