04-19-2008
Owner, Green Bay Packers
That's the trouble with paint. Once you commit to it, be it on brightwork or topsides, you're pretty much stuck with it. That being said, you may try stripping it with an appropriate stripper and then using bronze wool to clean it, which will leave some paint in the pores of the wood. sometimes that appearance is acceptable as you may have seen some varnished floors within houses that have a certain streakiness under the finish in the wood grain that is the result of an earlier painting. If it is of an objectionable level you will be reduced to sanding, and the question there is how much wood material you have to remove to get the paint out. You could well have to remove an amount that will substantially reduce the proportions of your wood.
If you really want a brightwork finish, I'd strip it and then clean it with bronze wool, or sand it very lightly, and live with the "antiqued" look that remains.
Wm. F. Buckley, Jr.
