Old 04-20-2008
winethief is on a distinguished road
Refrigeration
I am looking to put a new refrigeration system in my Passport 40. I currently have the original Glacier Bay which has been fixed for the last time. I have already sunk about $2500 into it. Next time it goes out it's gone.
I am looking at Cool Blue which is not water cooled and only comes with one plate which doesn't thrll me. The other system I saw was a Frigo system which requires another through hull install, therefore more expensive all around.
Is there any other system I should be entertaining?
Many thanks,
Windthief
Old 04-20-2008
camaraderie's Avatar
moderate?
Check out the BD XP system from SeaFrost...they can make up systems for you with or without water cooling and with single or dual plates and all piping and fittings to your box specifications. Pricing is quite reasonable i think and I've had good luck with them and the product.
bd 12 & 24 volt
Note...the air cooled BD/XP version with two 12x21" plates and all fittings/thermostat is $2035, $2250 if you want it water cooled as well.
Old 04-20-2008
erps's Avatar
the pointy end is the bow
I had a Grunert double box systems fail shortly after we bought the boat. I pulled it all out and resurrected one of the boxes with an Adler Barber outfit for under $1,000. We're using it for a refrigerator box, but I went with the large evaporator so it could be used as a freezer box as well. Power consumption in our neck of the woods is good. I understand these outfits can be taxed in the tropics though. We considered a water cooled condenser but decided against after a little research on Robert Kohlman's (sp?) website.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 04-20-2008
bhcva is on a distinguished road
Seafrost
I'd second the Seafrost suggestion....Cleave Horton, the owner, has been terrific to work with.
Bruce
"Solitude" Caliber 40
Ches Bay
Old 04-20-2008
eryka is on a distinguished road
I reeeeeally like our Frigoboat keel-cooled. Yeah, I know, cut another thru-hull. But it's all worth it when we only use 18 amp-hours per day when we're in 70-degree water.
Refrigeration Conservation Cruisingdad Cruising & Liveaboard Forum 42 03-06-2009 10:37 AM
Adler-Barbour Refrigeration one blinking light SanDiegoChip Gear & Maintenance 11 06-13-2007 08:51 PM
Installing 12-Volt Refrigeration Sue & Larry Gear and Maintenance Articles 0 06-18-2002 08:00 PM
Installing Refrigeration Sue & Larry Gear and Maintenance Articles 0 05-08-2002 08:00 PM
