NMEA stds and Magellan 315 GPS - SailNet Community
Blogs
Old 05-31-2002
mikehoyt's Avatar
mikehoyt is on a distinguished road
Nav software often requires NMEA 183 standard. My Magellan 315 GPS has four NMEA settings - OFF, V1.5 APA, V1.5 XTE and V2.1 GSA. None say NMEA 183.
Are any of these NMEA 183?
Trying to link with Captain Voyager software. While Capn V does not find GPS, Hyperterminal in Windows shows the PC accepting data as described in the Capn V manual.
Any sugegstions or thoughts?
Mike
Old 06-03-2002
stach is on a distinguished road
Mike,
All those that you cited are NMEA 0183. They are just different variants of the overall 0183 format. I have a Magellan 320 and I have use/can use either of the 1.5 versions. 1.5xx seems to work with most software. The very lastest software may require 2.1
Old 06-04-2002
mikehoyt's Avatar
Stach,
Capn Voyager calls for NMEA 183B. Are any or all of those cited above B? The program is not finding the GPS. The program is version 5.3, perhaps that is the problem?
Thanks,
Mike
Old 06-05-2002
Mike,
Mike V2.1GSA is NMEA 0183B format so set your GPS to it. I''ve copied some Magellan infomation and included it below;
Please select a product:
CURRENT PRODUCTS
General
GPS Companion
MAP 330 FAMILY
GPS 315/320
DataSend
RECENT PRODUCTS
MapSend Land and MapSend Marine for the Map 410
General
Q: My GPS will not communicate with my computer what should I do?
A: Make sure the GPS Baud rate is set to 4800
Set GPS NMEA to 0183B or 2.1 GSA
Set COM port to 4800 baud, 8 bits per second, no parity, one stop bit and set flow control to hardware.
Disable or remove any conflicting software from the COM port. (Answering machines, fax software, personal organizers, etc.)
A: Contact Thales Navigation. customer service at 800-669-4477.
Q: How can I get a Magellan product catalog?
A: If you would like information about our GPS products, contact 800-669-4477 and select the literature hotline to have our product catalog sent to you. Or you may email us your literature request (see the General Information section of this website.)
Thales Navigation.
960 Overland Ct.
San Dimas, CA, 91773
(909) 394-5000
(909) 394-7050 (fax), or visit our website at www.magellangps.com.
General Information | Vehicle Navigation | Register Product
Consumer | Consumer Electronics | Ashtech Precision
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
