04-21-2008
One other major reason to do it that way is the swages at deck level will retain water, since they're pointed UP, and that leads to the wire corroding. Mechanical swageless fasteners can be taken apart and inspected and are less prone to that type of corrosion from what I've seen.
As for getting new rigging... RiggingOnly has some of the better prices, but you're probably going to want to go local, since shipping the stuff will cost a fair bit.
