Old 04-21-2008
jmunson2's Avatar
jmunson2 is on a distinguished road
Tachometer/ignition switch for Perkins 4-108 M
Namaste!
I am researching a new tach/ignition switch for our boat, a '71 Cheoy Lee 42. She has the above engine.
The old tach glass burst last year and the bugger didn't work when she was bought as well - so we knew it needed replacing. Also, the ignition switch setup has corroded considerably as well. Bottom line is, all that needs to be replaced.
I'm looking for advice for a new tach. I found a Faria tach, TD9181 (PN 34842). I assume we have a mechanically run tach by the cable and age of the engine. I suppose that could be wrong.
We'll also need a new cable, gear (if it uses such a thing), ignition switch, buzzer & stop button.
Please reply with pertinent advice, etc. I am redoing the cockpit panel (which is, honestly, a hodgepodge) and would like things to look nice and clean.
Peace, Love, and Light,
/s/ Jon C. Munson II
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 13 04-09-2008 12:12 PM
Ignition switch stuck in on position. padean Gear & Maintenance 15 09-24-2007 10:40 PM
Selector switch or Automatic Relay PBzeer Gear & Maintenance 17 09-04-2007 08:25 AM
Battery Switch johar Gear & Maintenance 4 04-08-2003 04:28 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
