Bottom paint over Gel Coat without Barrier Coat? - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 04-24-2008 Thread Starter
Sailermon: I only managed to scrape off the anti foul and barrier coat on roughly 1/3 of the hull before I quit. I still have anti foul (over barrier coat) left on the rest of the hull. If I want to sail this spring I have two choices: (1) Sail with the hull as is which means that roughly 1/3 of it (spread around the hull at various places where I scraped off the old anti foul that was cracking badly) would be gel coat exposed to sea water; or (2) Sand down the rough edges where the anti foul/barrier coat was scraped off and where the gel coat has been exposed and put a couple of coats of barrier coat over the entire bottom of the hull. I'll strip the hull to the gel coat in the fall. I'm just not sure which choise is the better one.
WagTheDog is offline
post #12 of 18 Old 04-24-2008
BarryL's Avatar
info
Hello,
IMHO, if you want to sail now, just apply antifouling paint and then splash the boat. If you want to apply a barrier coat next year, you will have to strip off all the paint (new and old) before you do.
I went through the paint strip, fair, barrier coat, bottom paint process this past winter. I did a write up on it, which you can read about here:
bottom paint 1, me 2, all done, test
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #13 of 18 Old 04-24-2008 Thread Starter
Barry,
Nice write up! I'm in exactly the same position money wise. Hopefully I'll be able to scrape together $1,000 to have the boat soda blasted in the fall. A couple of coats of antifoul it is then. I just wanted to make sure that a season without barrier coat in some places would not cause blistering.
Regards,
John
post #14 of 18 Old 04-24-2008
JimsCAL's Avatar
It sounds like the 1/3 that you scraped is ready for new barrier coat. I would apply barrier coat there and tackle the rest next winter.
JimsCAL is offline
post #15 of 18 Old 04-24-2008
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
Howdy..
Here's a thread... but maybe it'll be important for you next year...
Vinylester Resin - Barrier Coat
I just want to emphasize one thing. I think it's important to not apply barrier coat to bottom paint...I also know how hard it is to completely get bottom paint off... I'm not a bottom expert. Search this forum.. you will find good info...
For the record... I was looking for 10 years of protection.
I went for 14 coats of epoxy...(2 then 12 Interprotect)
3 coats of bottom paint (1 hard 2 soft... Petit)
craig
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #16 of 18 Old 04-25-2008 Thread Starter
Thankls for all the comments/suggestions. I guess I'll be doing the following:
- Sand down existing bottom cote to smooth edges where bottom coat/anti foul has been scraped down to the gel coat.
- Apply 2x layers of barrier coat to exposed gel coat.
- Apply 2x layers of bottom cao (anti foul) to the entire hull.
This should afford the hull sufficient protection of the season. Then in the fall...SOAD BLAST! Gotta save some money though!
John
post #17 of 18 Old 07-15-2012
Re: Bottom paint over Gel Coat without Barrier Coat?
Ok newbie question coming...
with boat on the hard how does one apply the bottom coat, where the 4 jackstands that hold up my boat, touch the hull?
Boat currently has a fairly decent looking BOTTOMKOTE RED XXX, INTERLUX so I was just planning on adding another coat before fall in prep for launch next spring.
Will add some pictures later Sunday when I return from the boatyard where she sits.
i_amcdn is offline
post #18 of 18 Old 07-15-2012
tommays's Avatar
You do NOT move things around with 4 stands as your supposed to have six and REALLY need seven
jppp likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Paint Build-up or Barrier Coat? cas8100 Gear & Maintenance 29 05-09-2008 11:25 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
bottom paint barrier coat rbh1515 Gear & Maintenance 2 02-25-2001 03:52 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
