bilge pump blowing fuses - Page 2 - SailNet Community
post #11 of 19 Old 04-26-2008
Handsome devil
Stillraining's Avatar
Already handled accordingly..
My bilge is different then most with a separate small extra deep depression which will only house one pump and switch..
The third big pump is under the engine
Stillraining is offline
post #12 of 19 Old 04-26-2008
You can tell allot about a man by the way he keeps his bilge. very nice Rain
bubb2 is offline
post #13 of 19 Old 05-13-2011
CapitainMike's Avatar
Originally Posted by mauidan15 View Post
So as the title says the bilge pump keeps blowing fuses, the wiring is getting wet so should I just try to rewire it, or install a new one?
Please be more precise what wiring is getting wet and where.
What is the make of the pump
What is the size of the fuse you are using
Is there a recommended fuse size for that pump
Are you using a float switch
What are the amps of the pump
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
"Money won't buy you happiness but it will allow you to buy a yacht big enough to pull up along side it"
"Please God be kind to me your sea is so wide and my boat is so small"
CapitainMike is offline
post #14 of 19 Old 05-14-2011
Originally Posted by Stillraining View Post
Buy a new one! cheapest insurance you can buy...also replace your fuse it my be worn out and tripping prematurely ..I have had a few go bad they are just like any other mechanical/electrical device in wet environments
Im a bilge pump freak...I have 4 on-board...3 electric and one manual...one of the electric is manually switched and big...the other 2 are auto switched one mounted slightly higher with an audible alarm ...
I am a bilge pump freak too. I don't even have one, manual or electric, but then neither do any of the other Etap owners! I do of course have a sponge and a bucket, as we all do.
Gary H. Lucas
GaryHLucas is offline
post #15 of 19 Old 05-14-2011
3 year old thread
cruisingdream is offline
post #16 of 19 Old 05-14-2011
mitiempo's Avatar
Not any more!
Brian
mitiempo is offline
post #17 of 19 Old 05-15-2011
Gary H. Lucas
You ETAP owners keep on about unsinkable that's really great but I think you have missed the point here. If you get holed below the water line you have to keep your batteries dry for obvious reasons and if there is no wind you are relying on your engine
I have 4 working bilge pumps, fore peak 1 manual. 1 saloon auto and manual plus float switch, 2 in the engine bilge auto with sensor its the deepest bilge in the boat and a spare pump and float switch.
If it starts to come in you got to get it out fast and a bucket is not a good idea.
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
post #18 of 19 Old 05-16-2011
Gunk in the bilge
I had the same issue with my bilge pump just now and it turned out, as far as I know, to be a little hard chunk left over from last years projects that was sitting directly under the impeller in the base of the bilge pump. I'm assuming it fell out when I removed the top of the pump to see what was going on. Lesson I learned is to look for the physical culprit first before going after a potential electrical issue.
Scott
Currently cruising down the Leeward Islands. Check us out at... Windtraveler or on Facebook at... Windtraveler | Facebook
smeyers18 is offline
post #19 of 19 Old 05-16-2011
Put a stainless strainer round it and clean it regularly. its some thing that should be carried out on a regular basis'
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
