Old 04-26-2008
safarisurf is on a distinguished road
Wiring an Amp Gauge
Hi I have a SW marine amp gauge with internal shunt that I'm installing in my boat. It came with no wiring diagram but I found some generic instructions on the web. The instructions I found show one wire to the battery connection at the starter, and the other to the key switch.
I'm wondering if these are automotive instructions and may be different than a multiple battery marine application. (seems like maybe the battery switch should be involved rather than the key?)
btw, this is for a Volvo MD1B with starter/generator unit and two batteries
Thanks.
Old 04-27-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Safari, which way you wire it depends on what type of gauge you have (+ & - or just +) and what the scale is.
IMHO, if you are using a battery changeover switch, the most useful place to put it would be in the common connection to the battery switch ie. existing switch common wire to guage, new wire from gauge to switch.
I hope this helps.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 04-27-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Internal shunt ammeters can be put in anywhere as long as the current doesn't exceed their capacity. Doesn't really matter if it is in the positive or negative lead as long as the current doesn't exceed it's specifications and the leads are connected in the proper polarity. Use a small test load, like a 5W light and a couple of small jumper wires to experiment with it if you are unsure of the markings. By convention, the external shunt type ammeters are placed in the negative common lead from your battery bank DC common to the loads.
Whatever you do, make sure you place it somewhere where it is protected by breakers or fuses from exceeding its rated capacity. If it is internal shunt chances are it is not rated high enough to measure starting current, or alternator output, and is only suited for measuring house loads. I have two internal shunt ammeters, one measures solar panel output (always less than 5amps) and the other measures house loads (less than 25 amps). Neither is used to measure charging current, and the one high current device I have (the SSB) bypasses the ammeter.
Old 04-27-2008
Sea Slacker
brak is on a distinguished road
I did not know that. Is there a reason for that?
I connected my ammeter (built into the electric pannel) into positive lead for no reason other than that seemed like a "thing to do".
Old 04-28-2008
Hartley18's Avatar
Termite Fodder
..only that, done this way, it will continue to work when the batteries are isolated.
What you have done should work fine. Don't worry about it.
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 13 04-09-2008 12:12 PM
Fuel Gauge Problems trodzen Gear & Maintenance 14 09-05-2007 08:23 AM
Gauge Problems Mark Matthews Gear and Maintenance Articles 0 09-24-2002 08:00 PM
Wiring Windlasses SailNet Gear and Maintenance Articles 0 09-19-2002 08:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
