Catalina 34 Starting Battery Problem - SailNet Community
Blogs
Old 06-03-2002
Garytami is on a distinguished road
I recently purchased a 1989 Catalina 34 with a 23 hp Universal Diesel. I was having a problem starting the engine on the cranking battery so I put in new Interstates for both the house and cranking battery. I have a good West Marine shorepower battery charger that keeps the bateries fully charged and I have checked the batteries with a hydrometer. All is OK. My problem is that even with new batteries, I cannot start the engine on the cranking battery alone. I always have to use "all" to get sufficint power to start the engine. Has anyone else had this problem on a similar boat? I am not sure if I should be looking for corrosion on the wiring terminations or if there may be a deficinecy in the original Catalina wiring?
Thanks for your ideas
Old 06-04-2002
lgsailor52 is on a distinguished road
Look for corrosion at the terminal connections and your ground. Also look at your power (battery) switch. There may be internal corrosion, or corrosion at the connections. A loose connection may also be the cause.
Old 06-04-2002
Jeff_H's Avatar
Super Moderator
You may also have a starter on the way out.
Old 03-06-2010
gulftex is on a distinguished road
c34 starting problem
I have a 1986 c34.Ihad the same problem,I had to use both battries to start.I relaced all battry cables with larger ones (welding leads) Battries were so far from engine small cables could not handle the draw.Installed two Wal-Mart marine battries,engine now starts on one battery.If your starter battery is close to engine,Iwould check connections and starter.
Gulftex
c34 hull#13
Old 03-06-2010
mitiempo's Avatar
Also check that your glow plug wiring is good if you have them. A lot of Catalinas were wired with the glow plugs getting their power through the panel with small wires. The best solution is to use a solenoid off the engine panel and wire the glow plugs direct from the start battery if this is the case.
Brian
Old 03-06-2010
olson34 is on a distinguished road
Cool "regarding fixin' what aint broke"
Strictly in the "FWIW" dept, at about a thousand hours I pulled the starter off of our 23 hp diesel (Universal M25XP) and took it in for a preventative maint. rebuild.
BTW, the inner of the two bolts required a swivel socket and copious swear words.
It had been working OK, starting the engine on either battery.
A mechanic friend advised me to go ahead and do this, as a p.m. idea.
About $135 later it was back, rebuilt, with a new solenoid (they are evidently not a rebuildable item).
The shop is a highly-regarded local marine starter/alternator shop and the proprietor is always willing to explain stuff. He liked the idea of "fixing" this before it might let me down in the midst of summer vacation cruising.
The punch line: it cranked the engine a LOT faster when reinstalled!
So, what slight little lesson there is to be learnt here is that sometimes these parts wear very slowly and performance degrades... slowly...
It's kinda like pulling the injectors and testing the spray pattern every so many hours, it pays to have an engine maint. sched.
As Forest said, "That's all I know about That."
L
Old 03-07-2010
Maine Sail's Avatar
There is something wrong and it's very unlikely that it's your batts. That starter is a .8 Kw and should easily be started by even a personal water craft battery.
Check:
1) Starter ground to engine (it is case grounded make sure it is clean)
2) All connections
3) Circuit path to starter
4) Starter
5) Battery switch
6) Glow plug circuit and glow plugs. (it is not clear whether it is not cranking or starting)
Also post this over on the C-34 forums (LINK)
______
-Maine Sail / CS-36T
Battery loses charge svzephyr44 Gear & Maintenance 1 09-28-2004 03:20 PM
Battery Charging Question gwp Gear & Maintenance 6 05-08-2004 12:28 AM
Battery Switch johar Gear & Maintenance 4 04-08-2003 05:28 PM
Adding 2nd Battery...help redbeard58 Gear & Maintenance 2 03-03-2003 07:13 PM
Dual Battery Installation Urband Gear & Maintenance 1 03-25-2002 09:57 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
