roll your own tethers - Page 3 - SailNet Community
post #21 of 34 Old 04-30-2008
CLucas's Avatar
Send a message via AIM to CLucas
Yup. Check this at Wichard for more info: Wichard Product Bulletins
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #22 of 34 Old 04-30-2008
I don't discuss my member
zz4gta's Avatar
Originally Posted by Plumper View Post
Using a piece of rope for the tether is fine in my opinion. They key thing is to be able to undo it, under load, at the person end in case you get trapped somewhere where you don't want to be.
Couldn't agree more. A length of line will work just fine, but make sure you can detach from it quickly under ALL your body weight. Litterally hang youself by your tether, and try and release yourself. A large snap shackle is a great investment.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #23 of 34 Old 04-30-2008
You can buy a harness for a hang-glider, you can buy a harness for rappelling from a helicopter, you can buy a proper harness with lights and whistles.
A sail maker can sew up anything you could dream of and the materials are extremely strong. Your possibilities are endless.
knothead is offline
post #24 of 34 Old 08-18-2008
Just remember to put a snap shackle on the end attached to YOU!
Do NOT use a carabiner to attach the line to your harness. You must be able to release yourself even under load.
And I wouldn't use a climbing carabiner to clip onto the jackline either. They are NOT SS and not made for a marine environment.
That said, no reason you can't make up something just as good as store bought.
sailordave is offline
post #25 of 34 Old 08-18-2008
Allanbc's Avatar
I have been a caver for almost 30 years. I've made my own harnesses and gear and trusted my life to it many, many times. I have no problem with making my own jacklines and tethers. As already pointed out, just use the proper gear for attachments.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
post #26 of 34 Old 08-19-2008
EO32's Avatar
I find this thread funny.
On one end, there are people that will buy the best and sue if it fails.
On the other end, there are ones that hook it up and use it.
I lean more towards the latter. You hook a line up to pull your 20,000 lb sailboat upwind without worrying about it, so what’s the big deal about hooking a line to your body. Sure I’d test it, at the dock. Do a couple of falls, see how it feels. adjust the lengths.
I do admit, I’m an engineer, so I take this stuff for granted, but if you want to buy or build a tether, go for it. It’s better than not using one.
BTW: This is my next project, so let’s keep talking about it.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
EO32 is offline
post #27 of 34 Old 08-19-2008
montenido's Avatar
Alright, great thread, but I have to weigh in also. Yes, I am fairly new to sailing, but I am not new to using webbing, ropes and carabiners in lifesaving conditions. I also bought a pair of 40' jacklines on ebay. Very well stitched with good quality hardware and top-quality webbing. People, these materials are so strong that they will never feel your weight if/when you fall and are restrained by them. The 1" webbing is rated for well over 1000 lbs breaking strength. The same holds for well-tied knots in quality rope. When you go up the mast using your good condition halyard (tied with a bowline), it is so much stronger than the load that you are applying that the safety factor is probaly more than 10:1.
Check the knots and stitching of any sewn loops in any safety gear, no matter the brand name or the amount of $ spent. That is just prudent.
Keep up the great threads. I am learning so much from you all.
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
montenido is offline
post #28 of 34 Old 08-19-2008
If you did a bit of research, you'd realize that the breaking strength of tethers and jacklines needs to be far higher than what you might expect. The momentary shock loads on a jackline can be very, very high. A person falling across the boat and getting stopped by the tether may generate upwards of 20 G's of force on the tether. If they weigh 180 lbs., which isn't all that heavy, that means the shock loading is 3600+ lbs. Then add in the mechanical advantage caused by pulling at a near-perpendicular angle to the jackline... and you've got some really serious forces involved.
Also, on a typical small sailboat, where the halyards are 3/8" polyester double braid, the breaking load of the line is about 4400 lbs. If tying a bowline only has at best 60% of the breaking strength of the line, you're now looking at 2600 lbs... Which isn't much more than 10:1 for a lot of the sailors I know—and that assumes the line is in perfect condition, without chafe or UV damage—not generally the case.
Also, consider that the shock loading caused by falling may be an order of magnitude more than what you actually weigh, the safety margins aren't all that large.
BTW, this is one reason I upgraded my halyards to spectra cored lines of the same diameter...to get a greater safety margin even with some wear and tear on the lines.
sailingdog is offline
post #29 of 34 Old 08-19-2008
1000 lbs is only a bit over 20% of the ORC recommendation (kindly provided by SailorMitch).
Jim
SEMIJim is offline
post #30 of 34 Old 08-19-2008
EO32's Avatar
The other factor, stretch, will spread the decelleration over a longer time lowering the peak force.
Of course if you stretch to far, you might go half way over.
- E.B. White
EO32 is offline
Basic Roll Tacking PJ Schaffer Racing Articles 0 05-13-2001 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Learning to Sail Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Seamanship Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Cruising Articles 0 05-06-1999 08:00 PM
