04-29-2008
Catalina 38 Avantura
It looks to me like the rudder is trying to drop loose, but the key in the first picture may be frozen into the keyway, which is now jammed into the top of the rudder tube (the fiberglass tube the rudder shaft is going through). I would bet that if you jack the rudder up, which will unjam the key from the fiberglass, it will turn. Once you remove that key I think it should drop out.
FYI, if you look at your tiller where it attaches to the rudder post, I bet you will see a notch in it that fits over the key. This would be what enables the tiller to turn the rudder without slipping on the rudder shaft.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
