04-29-2008
Gemini 105Mc Hull 987
I'd quess your batteries have been overcharged by your wind gen all winter and have cooked off. AGM's are very sensitive to over-voltages and if they were not set properly (every manufacture has a different high end, but most will burn if over 14.1v is applied). Have you ever looked on a windy day to see how much voltage is being put out by your AirX? They can get scary high if not regulated well including having a shunt to dump to if they put out too much. I'm not sure if the Link 2000 has a shunt built in to it, I don't think so.
Altho it seems Cam and I are saying the opposite (I say over charge, he says under charge) it comes down to dead batteries. Wet cells are easy to check, simply look and see if they are dry. You don't have that option.
Cam's checks will tell you the state of your batteries, start there and see what is going on. If they take a charge I'd still consider them suspect as to how many ah's they will hold.
