How long will a fiberglass boat last - Page 2 - SailNet Community
post #11 of 12 Old 04-29-2008 Thread Starter
sailbot's Avatar
They were piled up on shore and workers with chainsaws started cutting them into pieces (if you want to see the saddest sight of all, that is it). Anyway, I noted the amount of effort that went into cutting these boats apart. Once the job was done, I went and inspected the cuts of fiberglass and the pieces. I can say one thing - across the cut fiberglass on these boats looked nice, green, dense and most certainly had shown no signs of weakness.
Wow Brak thats encouraging . As far as fixing blisters goes It would only be for saftey, I dont care about cosmetics under the water line, and I really not that concerned about resale ( It would be like selling your own child) I want to hold on to my Crown for while, and between you and me I didnt pay that much for her anyway.
Do you guys thimk the hull will just break apart one day if the blisters aren't fixed.. ?
A King needs a Crown
sailbot is offline
post #12 of 12 Old 04-30-2008
artbyjody's Avatar
If you do not get them fixed - the cosmetic blisters can get bigger or spread. Most people think fiberglass itself doesn't suck up water - but it does and all those little strands exposed - eventually will suck up water like a sponge. If you intend on keeping her - you'll want to at least address it perhaps in the fall when the season is over.
Will your boat sink as it stands - probably not unless you let the issue continue for years and no attempt to fix is made.... But if the blisters are severe enough - it will make fixing the issue slightly more work later.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
Mr. Renovation GoodOldBoat Good Old Boat 2 12-28-2009 02:56 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Naming and Renaming Your Boat Sue & Larry Buying a Boat Articles 0 12-15-2003 07:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 08:00 PM
