Old 04-30-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
Securing holding tank
i'm installing a new holding tank in the v-berth. (no previous holding tank) the backside will be against the bulkhead and the two sides are wedged against the hull and a bumpout in the v-berth. i was thinking wrapping the tank with plastic then pouring expandable foam underneath it to keep it in place. then on the accessible side glassing in some plywood to keep it from moving. my thinking with the plastic over the tank is if i ever have to remove it, the foam won't be bonded to the tank. any thougthts?
wchevron
s/v Time Flies
'78 C-30
Old 04-30-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Sounds like a good plan wc. One thing I would add though, is to also fasten the tank securely to some structure, perhaps by using welded tabs if a stainless tank, or banding the topside with strapping if a plastic tank.
Perhaps the form-fitting installation at it's sides and bottom is sufficient, but think what may happen to an unsecured holding tank during heavy seas, or a knockdown.
True Blue . . .
sold the Nauticat
Old 04-30-2008
fcsob is on a distinguished road
To hold my 35 gallon tank down we use stainless ratching tie downs. It will be able to be removed if needed.
Old 04-30-2008
wchevron's Avatar
Detachable member
tb, good thinking about strapping down the top. thanks.
wchevron
s/v Time Flies
'78 C-30
Old 04-30-2008
BenthosCritter is on a distinguished road
I would consider some thru-bolted pad eyes attached to some straps.
Benthos Critters United.
Holding tank or Fuel for Jeanneau Myblueheaven Gear & Maintenance 10 05-05-2009 01:37 PM
Holding tank location stoutwench Gear & Maintenance 17 04-11-2007 02:40 PM
Custom Holding Tank Mithril Gear & Maintenance 6 03-15-2007 03:48 PM
Holding Tank Questions John_colpitts Gear & Maintenance 14 08-31-2006 06:42 PM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
