04-30-2008
Gemini 105Mc Hull 987
Short answer is it depends.
Long answer, it depends on why it would not go up, or down. Your surveyor was a bit negilent, he should have told you why it would not move/function.
If the board is steel it could be so coroded that the rust/scale has expanded it and made it so it will not fit in the slot.
The fix there is a new centerboard - a chunk of cash, but doable. I've got a friend where his (IIRC) Merit, or Helms 25 centerboard got stuck, he had to have it cut out and is replacing it with a new steel plate.
Or the mechanism for raising and lowering the board could be broken and not repairable or just need new cable - even that goes from simple to major as lowering the board might not be possible in the slip or on the trailer; requiring you to pay for a boat lift to simply extract and rehang the board.
I would go back to your surveyor and demand a more informative answer.
