04-30-2008
I need help running halyards...
On the O'day 192 I just bought, the two halyards are run back to the winches on the cabintop, but they are run through stand up blocks, but when tight the blocks pull back and allow the halyards to rub on the cabintop, can I replace these with a cheek block? Without drilling new holes? There are 4 bolts for the stand-up block, and they were not well installed, both leak. Maybe I should plug them up? cheek blocks only use 2 bolts right?
Siren 17 #1094 "Minuet" (first boat)
O'day 192 #488 "Aria" (second boat)
Hobie Wave #2697 (current boat)
Hunter 27 #716 "Revival" (current boat)
