05-01-2008
Originally Posted by chtaylor
Thanks for the responses!
I'm planning to put four stand-up, spring-loaded blocks at the base of the mast - two on each side. I don't have a real headliner in the cabin - just a fiberglass ceiling; so it will be easier to drill through and use backing plates.
From the blocks, the lines will lead to turning blocks (deck organizers), then to either cam cleats or rope clutches, and finally to the winches.
Also, my boat has moulded-in pads on the cabin top that appear to be intended for winches.
Charles
There are special turning blocks meant for this job that do not need spring stand-ups... require more care in alignment and installation, but look tidier.
Suggest you use rope clutches rather than cam cleats... frees up the winches for other duties. If you use cam cleats you'll need fairleads behind them, just as many holes if not more.
The molded pads will likely be strong enough, and hopefully originally engineered for winch loads.
1984 Fast/Nicholson 345
