Old 04-30-2008
zoom555's Avatar
1973 Northern 25
zoom555 is on a distinguished road
Seized turnbuckles
As I've been doing repairs and running over everything on the boat this spring, I've discovered that several turnbuckles have become quite seized. The standing rigging was replaced by the prior owner about four years ago and is generally in good shape, but the turnbuckles are of the closed variety, which I understand are more prone to seizing because they retain moisture.
In any event, the teflon based lubricant I used for lubrication last year isn't loosening up these seized turnbuckles. Does anyone have a suggestion for what I should try next? (WD-40? Something nastier?)
Old 04-30-2008
max-on's Avatar
1997 Dehler 33
max-on will become famous soon enough
I would try a penetrating oil made for the job, something like KanoLabs.com. Once undone, I would apply Lanocote Forespar: Marine Products that Perform or a similar product to the turnbuckles.
Old 05-01-2008
knothead's Avatar
Use a good penetrant such as PB Blaster or an equivalent product. Apply a squirt at the top of the barrel and in the hole in the center of the barrel every few days for a week or two and then give it a try again. If that doesn't work you may be forced to use a judicious application of heat. Don't get the thing red hot though.
If you are successful in getting them to turn then use your Teflon lube and exercise them once or twice a season.
Next time your re-rig, use bronze open body turnbuckles. With enough neglect they will seize too but not nearly as much as closed body stainless ones will.
37 rats, 6 cats seized from man's cabin - AZ Central.com NewsReader News Feeds 0 01-09-2007 01:15 PM
BVI Boats Seized by US Customs VIEXILE General Discussion (sailing related) 2 07-16-2003 04:05 AM
