Old 05-02-2008
arghhh is on a distinguished road
Square wave will power most computers just fine as the power supply will regulate it. It might draw a bit more power, buzz or get warmer but nothing to really worry about unless it is excessive. Cordless tools are a different story, some of the chargers are very cheap and basic and can toast on a square wave inverter. Usually you can find information about it in the manual where it will say you shouldn't use it on a inverter or not.
  #12
Old 05-02-2008
Fareast is on a distinguished road
Thanks for the information, I will try and contact Ryobi and see what they say.
Mike & Paula
S/V Tivoli
  #13
Old 05-02-2008
nightwatch is on a distinguished road
I have ran my Mac laptop and my very old 9 volt Makita for years without a problem. Currently using a Xantrex 1800 inverter. It also runs my Sears refrig.
  #14
Old 05-02-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Originally Posted by Idiens View Post
I've taken to running my PCs off DC/DC converters.
Mainly because I can't make up my mind what size and type of inverter is the best choice.
I have had big problems with these. The universal plugs don't fit well, and I generally shy away from anything using a conventional cigarette lighter plug on boats. Also, HUGE amount of RF noise even with a ferrite. With the DC/DC I could not use the laptop for wefax, and had to turn it off when using the SSB. I could do both with a cheap inverter and the stock laptop power cord. Currently looking for a good, relatively inexpensive inverter as my cheapo inverter has died.
  #15
Old 05-04-2008
wingNwing's Avatar
formerly posting as eryka
wingNwing is on a distinguished road
Thanks, everyone. I've been skeptical of those DC/DC converters too, but am not sure if our $99 special inverter from Radio Shack is a whole lot better. Will do a little more searching then make VERY sure all our data is backed up before we try to run the laptop from it.
You may post attachments
You may edit your posts
Wind, Waves, and Sailors Michael Carr Seamanship Articles 0 09-18-2003 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
SEO by vBSEO 3.6.1
