Cam, bear in mind that "ships power" is not simply 12-volt power.
It is nominal 12-volt power, actually 14.4 when the alternator is running, sometimes higher if other power sources are running, 12.5 with a good battery bank and 12.1 when the house batteries are halfway depleted.
Whether a "12 volt" electronic device will be happy with all that is unpredictable. ICOM's ham
radios are designed for mobile use--but at 13.8VDC, and they often have performance problems at 12VDC. "Close" just often isn't good enough. In fact one of their
radios is infamous for being desinged with components that are underated for 14.4VDC use, sometimes they simply fail when used in vehicles because 13.8 is marginal and the normal 14.4 is beyond marginal. And that's from a name brand of 'expensive' electronics.
You can either gamble the price of the device, or check with the maker (who will usually say "Huh? Oh, we don't warranty that.") or use a dc-to-dc converter, set for 12VDC output if that's what the gizmo wants.
Something that ships with a car lighter adapter--not just a 12VDC wall wart--is more likely designed to work with the whole voltage range, no gamble needed.
Polaroid, btw, has no relation to the old Polaroid film company. They went broke,liquidated, sold off all the assets including the name. The new owners are a totally new outfit.
