05-01-2008
Gemini 105Mc Hull 987
rlevy, you don't have 10 post yets so can't send PM's (Private messages).
Forgive me hijacking your thread - below is a complete parts list for your engine, I believe you need a new solenoid.
Starter Solenoid part no: 301933
The parts list is available from this link: Engines1 | Westerbeke, Universal, Marine Engines, AGM Batteries, Engine Controls Knowledgebase
M-12:
1983-1988
UNIVERSAL DIESEL ENGINES
Description
Part #
Description
Part #
Air Filter
301926
Oil Pressure Switch
299964
Air Filter Element
301049
Panel, Standard
300680
Alternator
42847
Panel, Deluxe
300685
Ammeter
300668
Panel, Custom
300690
Belt
301073
Pump, Fresh Water
301336
Dipstick
301212
Pump, Mounting Gasket
301340
Exhaust Manifold
300802
Pump, Rebuild Kit
N/A
Exhaust Manifold Gasket (A)
301245
Pump, Sea Water (E)
42175
Filter, Lube Oil
300209
Pump Mounting Gasket
302678
Filter, Fuel Oil
298854
Pump, Impeller
302875
Filter, Electric Lift
300128
Pump, Repair Kit
N/A
Gasket, Head
301120
Pump, Seal
302885
Gasket, Oil Pan
301209
Pump Conversion Kit (Includes Pump)
302835
Gasket Set, Upper
256840
Pump Conversion Kit (Excludes Pump)
302838
Gasket Set, Complete
256841
PTO Pulley Kit
303068
Glow Plug
301754
Pump, Fuel Lift
301385
Harness, 5 Ft Ext.
300708
Shim, Cylinder Head
N/A
Harness, 10 Ft Ext.
300675
Spare Parts Kit A
256910
Harness, Engine
298586
Spare Parts Kit B
256829
Heat Exchanger (B)
298633
Starter
301295
Heat Exchanger End Cap
299838
Starter Solenoid
301933
Heat Exchanger Gasket (C)
299838
Tachometer
300684
Injector
301109
Tachometer with Hour Meter
300687
Injection Pump
301121
Tank, Coolant Recovery
300238
Injection Hardware Kit
N/A
Thermostat Element
301358
Injector Nozzle
N/A
Thermostat Element Gasket
N/A
Injector Return Line (D)
See Below
Thermostat MTG Gasket
300237
Isolators
300794
Valve Cover Gasket
301239
Ignition Switch
300671
Water Temp Meter
300670
Manual, Operators
200155
Water Temp Sender
299066
Manual, Parts
200137
Water Injected Elbow
N/A
Manual, Technical
200158
Zinc (F)
301069
Oil Drain Washer Kit
301431
