05-02-2008
Boat Centering Gadget
When I was a kid, my dad had a Catalina 22 Sailboat. We used to trailer that a lot and we had the same problem that you do. A lot of times just as we would crack the boat on to the trailer rollers, the boat would float a little off to one side or the other and the keel would be partially or fully off. We then would have to refloat her again and I would push a little while my dad pulled the car up again. Odds were 1/4 that we got it rigght the first shot..
So one day, I bolted two 2X8 to the frame of the Trailer in a slight V on each side of the keel plate on the trailer. The keel was about 6 inches wide and about 4 ft long, so the front of the V was roughly 6 inches wide and the back about 8 inches in the back. The boards were about 6 feet long, so we had about a foot in front of the keel and a foot in the back. On the insides we attached astroturf.
Centering the boat was easy now. As long as you got the leading edge of the keel in the slot, the eight inch high wedge lined it up perfectly as you cranked it on. Even if the keel was all against on of the boards, the keel only hung over the base plate by a 1/2 inch at most. If you really screwed up and the leading edge went to the outside of the board as you were cranking, the angle the keel was deflected was a easy give away that you were not lined up.
I think it cost us like $15 and a hour to make, but probaly saved us 10 minutes each time we pulled the boat out of the water.
Several people asked us what it was and once we told them, they wanted to know were they could buy one.
DrB
