05-02-2008
Best Looking Moderator
Seems like you have to unscrew the collar, hold the ring, and give a quarter turn counterclockwise, then pull. Probably hard to get out if it has been in there a while..
There should be a rubber gasket that closes to reduce the water intake. Stick the plug or any plug in there if your boat did not come with one.
I use bilge cleaner and a tooth brush (usually my mother in laws) to clean the crap off of there. Depending on how long it has been, you will need an ice pick or screw driver to get off the freaking barnacle farms. Some people at the dock have told me to use muratic acis or soak in Cl but I have not had the heart to try that yet. I know muratic acid takes them off, just concerned about its effect on the wheel, etc. Why don't you try it and let me know?(smile).
Hope that helps.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
