05-04-2008
Okay, here is the deal...I talked to a mechanic at our marina and he came aboard to diagnose the problem. The pump is supposed to run when the key is in the on position. My engine wouldn't start because it was drawing air from somewhere. After bleeding the system, it started and I let it run for a couple of hours, checking where it could possibly be getting air from. I finally found that it was the bleeder screw on the top of my fuel filter. The top of the filter was wet with diesel. I wiped it off and a few minutes later it was wet again. Ha! Well, I tightened the screw and it didn't tighten. It is stripped. Problem is, it is not the bleeder screw that is stripped. It is the filter body. My plan is to replace the filter body and I should be up and running. Any tricks to replacing this?
-Riz
