05-03-2008
Originally Posted by Neicy
The boards on my boat are loose, there are approximately 6 pcs, 2x3, and 3 pcs 1x2 plus the cut outs in the shower, head area. My plan is to remove them, bring them home to sand, refinish etc. So In the opinion of you that have used it, would it be easier to just remove and do them all at one or say 3-4 pcs at a time. Thanks for you thoughts.
I'd do them all at once if you have the space to lay out all the pieces (flat and level is best)
Also lay it on quite wet.. if you try to "stretch" it out as you go it can dry looking a bit streaky.
I think you'll be happy with the look - the nonslip nature is surprising.. we put it on our table too and you can feel the drag when you wipe it with a wet cloth.
1984 Fast/Nicholson 345
