05-05-2008
Most common water heater arrangement is that engine cooling water/antifreeze mixture goes from the engine to a coil in the water heater, then to the heat exchanger, then the pump, then back to the engine. Salt water (or lake water) comes in the thru hull, to a screen filter, to the other pump, then to the heat exchanger, then the waterlift muffler, then out. Theory is that the water/antifreeze mixture heats as it the engine is cooled, the heat then goes to the water heater where some of the heat is lost for benefit of your shower, then in the heat exchanger the rest of the heat goes away so the antifreeze can cool the engine again. If your heat exchanger is plugged up, your engine will overheat. But if your thermostat is defective, your engine will take a long time to come up to operating temperature, thus your water heater will not have a hot engine to heat up your shower! Therefore, before you spend a lot of time and effort cleaning the heat exchanger, take a peek at the engine temp gauge - it may be that a new thermostat or radiator cap is the first order of business! By the way, regarding plugged heat exchangers - a wise sailor once told me that once a year you should look at the rubber impeller in your salt water pump. If it looks perfect, throw it away and put in a new one! What he meant is, replace it before it fails, so you don't have to take the pieces of a disintgrated impeller out of your heat exchanger. On my boat that is especially good advice, since my heat exchanger is nearly impossible to reach. First time I cleaned it, it took 4 hours!
Don To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
