05-05-2008
External float switch
not timed, at the same level as the pump which may be the problem, probably should be above it a bit. Have had bottom screen off pump, impeller clear. Nature of construction is such that a bubble could get up into the impeller cavity. I don't remember, but I think there is a check valve. if there were not, the backflow would push out the air, but then risk short cycling.
