Hot watter via coleman propane camping heater? - Page 2 - SailNet Community
post #11 of 12 Old 05-05-2008
We own the Coleman portable hot water unit you mentioned. We are very pleased with it. Works well once you get use to how to control the settings. We converted ours to attached to 20lb propane tank. much better than using those small cans! We use in our sauna as will as on our boat. On board we keep it below and take it above when we want to use it. Attach to the 20lb. propane tank which we usually have out BBQ attached to and away you go! We put the intact (pump unit) in a plastic storage box you can get at walmart. Just remember they say not to use untreated water! So no lake water or salt water unless it has been filtered first.We stock up on water at various marinas we visit. It is amazing how little water you use with this unit.
You can also use it to do dishes! Good excuse for me not to dive into Lake Huron when the waters cold...brrrrrrr!
We can use it all summer 9 2 months without charging the battery.
Good luck, Allan
Allan C&C Less is offline
post #12 of 12 Old 05-06-2008 Thread Starter
SSBN506's Avatar
Thanks for all the help guys. I have learned allot mostly how to properly store propane. I think I will pick one up now that i have an idea how to safely use one. I love the suggestion of storing the propane in a vented bag over the transom.
Thaks
SSBN506 is offline
Propane Cabin Heater Mysun Gear & Maintenance 9 06-07-2009 11:29 PM
winterize hot water heater? saltypat Gear & Maintenance 6 10-26-2007 11:47 AM
Hot Water Heater Usage PBzeer Gear & Maintenance 38 01-21-2007 08:31 PM
hot water heater question primerate84 Gear & Maintenance 8 10-19-2006 08:24 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
