05-05-2008
I have the TackTick instruments on my boat, which I installed to replace the Raymarine ST60 instrument set (tridata and wind). The T104 setup comes with the Tridata and the Wind instruments as well as an NMEA 0183 interface. I am very happy with them... it was very worthwhile as upgrades go. The problem I was having with the ST60 instruments was repeated problems with the wind instrument failing to operate properly.
BTW, the TackTick wind instruments have a nice feature, since the display can be used for both normal wind instrument use as well as used as a close-hauled wind instrument. The normal use gives you 360˚ of wind angle, the close hauled mode only reports ±60˚ off the wind.
I finished a new mount for them earlier this week, where the instrument display heads are actually mounted to the port of a Beckson 5" x 12" port, to give the cabin additional ventilation, while allowing the instruments to be in a highly visible location. I'll post a photo of the installation later this week.
BTW, if you're feeling a bit lazy, the ST60 Raymarine tridata transducers actually work with the TackTick hull transmitter, since Airmar makes the transducers for both Raymarine and TackTick.
