Like Tree1Likes
  • 1 Post By beej67
Old 05-05-2008
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Yanmar GM30 To Hot Water Heater
Has anyone done the conversion for a fresh water cooled Yanmar GM30 to a hot water heater. What kit is involved ? Where is the hookup on the engine for the water/ antifreeze flow to the hot water heater? Do I need a different engine thermostat? Is there material I can downlkoad as the manual does not have the detailed information?
Thanks for your help in advance,
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 05-06-2008
beej67's Avatar
beej67 is on a distinguished road
I did it pretty much from scratch, and didn't have any problems. Look in your engine manual, at the coolant pump diagram, and there are two hex wrench plugs that come out, and go to and from the hot water heater. You need to provide your own tapered hose barb fittings, and may have to do some 'extensions' or elbows or whatnot in your plumbing to get the radiator hose between the pump and the hot water heater out of harms way. Don't forget the teflon tape. I put a couple of ball valves in-line on the out and the return too, just because it made me feel better about being able to cut it off on-the-fly, in case something went wrong with the hot water heater.
Lady C likes this.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Water Pump Yanmar 2GM20F puff6022 Gear & Maintenance 13 02-27-2008 09:16 AM
Water tanks and a hot day, be aware!!! cjmcfall General Discussion (sailing related) 6 08-06-2007 02:37 PM
No Hot Water Duke 7184 Gear & Maintenance 9 08-04-2007 01:46 PM
On demand water heater seadana Gear & Maintenance 2 02-05-2002 06:15 PM
Hot Water Heater Replacement sailthechesapke Gear & Maintenance 1 03-27-2001 10:27 AM
